1989 90hp.... motor is running good at WOT 5500 plus rpm, but at idle it smokes like crazy an very hard to put in gear to take off.as soon as the motor is good an warm it will idle while in gear, but if you shut it off an wait 10 min.s you have to go thru the whole routine trying to get it in gear without stalling. this last trip I used a wooded stick to measure my oil in the tank, ran about a gal of gas thru the motor at the lake and the oil tank was down over 2",THATS a lot oil..So I disconnected the VRO an unplug all the wiring, going to try an go on a test run and see if the idle problem is now gone..yes the gas is now mixed at 50-1...... this motor has new power pack, 4 new coils ( 260 volts), carb. rebuilt, every gas is new, new fuel filters..
