Blown496
- Jun 20, 2018
- 37
92 Mercruiser 305. The inlet hose connects to a pipe on the left lower side of the engine. Is that a one way valve? Do I need to pour antifreeze down that hose? Also, is pulling the hoses on both manifolds getting all the water out? I drained the block and pulled the tstat housing to replace the tsat and poured two gallons of antifreeze in. I rebuilt this boat from hull up and and had the out drive rebuilt so the new impeller has not been in the water. Just want to be sure I didn't miss anything. Thanks
