Water pump housing
brhodes
rookie, so bear with me, when I took off the top housing of the water pump, it lookes like it has something between the cup and the housing. I am guessing it could be a gasket, could be melted plastic. New top housing has a gap that looks like it could accept a seal/gasket. I have the manual, don't see anything, just double checking. Have a sierra kit, drive serial in my sig, mr drive. Thanks for any help.
bigskiohio
Master Chief Petty Officer
Re: Water pump housing
i asked the saame as mine had black stuff in there. i was told no seal just the slinger that slides on shaft and goes in top but it just sits on top not held by anything.
Bt Doctur
looks like some melted plastic from an overheat. check the pump base for melting where the shaft comes thru.
brhodes
Thanks for the help, already have a new base, will double check for other signs of overheat. Thanks again!
