Wet-v-Dry tune up adjustments on MC165 I6
Oshkosh1
Ensign
Hi all...
So I have my boat up and running well so far. One pump of the throttle and it fires up and idles without hesitation. Ran it up to 2500 RPM...immediate throttle response and no signs of stumble whatsoever.
I've set the dwell(31deg) and the idle(580RPM...in gear).
I know I need to check the timing(base to -6Deg BTDC...Advanced around 30deg) use my vacuum guage to tweak the carb from the suggested initial setting.
Should I wait until I get it wet to proceed, or can I go ahead and set these in the driveway also.
Will the added back pressure be of any consequence on these?
I read that I should have set the initial dwell at one or two degrees below the suggested "low" end as with new points the wear bar will conform(and wear) to the distributor cam quickly, therefore decreasing the gap("raise" the dwell number) more rapidly when new.
Thanks for the time!
Oshkosh1
Ensign
Re: Wet-v-Dry tune up adjustments on MC165 I6
"Bueller...Bueller...Anyone?...Anyone?...."
achris
More fish than mountain goat
Timing and dwell can be done on the muffs... Idle mixtures and speed can be set roughly on the muffs, but should be done on the water, as the back pressure on the exhaust does change things.. That said, if I can't get the boat to the water, I set the mixtures at the richest before the idle speed starts to drop, and the idle speed at about 50-100 RPM higher than spec...
As for dwell setting a couple of degrees low... Can't see a problem with that...
HTH,
Chris......
