- Jul 23, 2011
- 52,183
the edelbrock is a good manifold. same as the stock Volvo Penta vortec manifolds that I ran. go with a 1" minimum, 2" preferable carb spacer to increase plenum volume under the stock carb. will give you some tuning tips on the holley later
a good timing set (melling, cloyes or comp cams), a high volume oil pump from melling (and no, it wont suck your pan dry) https://www.melling.com/product/gm-cast-iron-oil-pump-select-performance/
threaded oil galley plugs vs pressed in
what RPM do you want to run? that determines cam selection
I would have the stock vortec heads modified for screw in rocker studs as well as the guide towers cut down for the better seals (about $100 charge). this is a must as the press-in studs will come out with eventually and unless you run beehive springs, you will mash the stock umbrella seals leading to oil consumption.
stamped roller rockers unless you want to upgrade to lighter valve train. then spend the extra $100 on aluminum
coated bearings is about a $100 charge. you may never need this, however if you ever loose oil pressure, it will save the engine from eating the bearings for about a minute giving you enough time to key off.
