What kind of glue should I use to glue the cushions to the plywood...I'm using regular OSB board and cushions from a couch I tore apart. Thanks in advance for the help
I Like 3M Super 77 Spray Adhesive. I also like to cover the foam with plastic using the spray glue. I used plastic bags from WalMart. Worked Great!!! Cheap Too!!!
Lol...I was planning on doing that too over the cushions to keep from chaffing the cushion...do you advise a layer of plastic between the wood and the cushion also?
Nope, none needed but I did glue it to the wood! Again, I'd use Ext. Grade plywood and I'd either paint it or at least give it a couple coats of Boiled linseed oil or marine varnish or polyurethane to seal it from the elements.
