what kind of glue?
jort15
What kind of glue should I use to glue the cushions to the plywood...I'm using regular OSB board and cushions from a couch I tore apart. Thanks in advance for the help
Woodonglass
Re: what kind of glue?
I Like 3M Super 77 Spray Adhesive. I also like to cover the foam with plastic using the spray glue. I used plastic bags from WalMart. Worked Great!!! Cheap Too!!!;)
jort15
Lol...I was planning on doing that too over the cushions to keep from chaffing the cushion...do you advise a layer of plastic between the wood and the cushion also?
jbcurt00
If you can, I'd use plywood rather then OSB, no matter how you seal it.
Woodonglass
I agree with this^^^^. IMHO OSB has NO place in a boat No Way No How Never Ever!!!! I Missed that the first time.
phillyg
No barrier between the cushion and substrate needed except the spray adhesive.
Woodonglass
Nope, none needed but I did glue it to the wood! Again, I'd use Ext. Grade plywood and I'd either paint it or at least give it a couple coats of Boiled linseed oil or marine varnish or polyurethane to seal it from the elements.
