Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
What kind of glue should I use to glue the cushions to the plywood...I'm using regular OSB board and cushions from a couch I tore apart. Thanks in advance for the help
I Like 3M Super 77 Spray Adhesive. I also like to cover the foam with plastic using the spray glue. I used plastic bags from WalMart. Worked Great!!! Cheap Too!!!
Lol...I was planning on doing that too over the cushions to keep from chaffing the cushion...do you advise a layer of plastic between the wood and the cushion also?
Nope, none needed but I did glue it to the wood! Again, I'd use Ext. Grade plywood and I'd either paint it or at least give it a couple coats of Boiled linseed oil or marine varnish or polyurethane to seal it from the elements.
