kat-a-tonik
- Jul 27, 2013
- 123
I have a 1972 StarCraft 14 ft aluminum V-hull with a 5ft. beam, what is the largest motor I can use on it
kat, i think everything on that page was a Starcraft. it's the brand name, not the model name.
they made lots of v-hulls in 14' with differing dimensions and hp limits. measure beam (max width at top edge of sides), and transom (flat thing on back) width, then start comparing it with the small utility tinnies listed to see which is closest. without knowing more, i'd guess that you'd likely be Ok with something in the 15-20hp range.
