where does o ring go
i have recently dropped the foot on my 60 horse johnson to inspect water pump. their is a small o ring that i am not sure where it came from. it is just big enough to slide down the skinny part of the shaft<br /><br />thanks in advance for any info<br />ps motor is early 80's model
OBJ
Re: where does o ring go
iceman....if the upper splines on the driveshaft has a grove at the base of them, that's where the oring goes.
thank you very much .i noticed the groove but i wanted to double check<br /><br />once again thank u very much
wayne h
Master Chief Petty Officer
dont forget to grease the shaft especially where it goes into the power head it will make it easyer to take apart next time around. i also anti-seize everything so there is not stuck bolts next time u wanna take it apart
