fireman57
- Aug 24, 2004
- 3,811
Trying to make sure that our 1978 70hp evinrude is timed right. Used Joe Reeves method but the timing will not change when adjusting the neoprene bracket on the plate that the roller cam rides on. Have good spark on each cylinder, carbs rebuilt, new lines on everything, new primer bulb, tank vented, etc.. have to pump primer bulb to keep it going at WOT and it will want to die at idle after about three or so minutes in gear. Can bump the key at idle in gear and it will pick back up. Losing patience. Can't find an air leak anywhere.
