Re: Winky Blinky?/?
this is not the smoothest running engine at low speed to start with.
you will need a Kv tester to check the secondary firing voltage.below about 600 RPM it fires all 6,between about 800 and 1200 it drops #5,between about 1200 and 1800 it drops 2 and 5.
Code 1 is normal, I dont think there is a code 12. you should have seen a code 33 then it changes to code 1.
