Walt T
- Mar 16, 2002
- 1,369
Re: Winterization - confusion
This discussion comes up every year like the Washington Redskins name debate every football season. Drain, adding antifreeze, whatever floats your boat. The corrosion prevention argument is meaningless as an engine will wear out long before any passages corrode through and this has been proven by millions of engines used in salt water. But hey, it's your boat and your money so if you feel better with antifreeze well then it's worth it to you is it not? I generally will point out that drain and fog is all that's necessary but then it's not my boat. None of us will care about your boat the way you do, so decide what you prefer and have at it. We all suggest not using toxic antifreeze. I heard a story of a guy starting up for spring and the antifreeze he drained out got a little spilled and he wasn't concerned. A neighbors dog found it. 'Nuff said?
