Re: Yamaha users manuals on line ???
I am in the same boat (no pun intended).  Today, I am replacing impeller and thermostat on 2000 100 4 stroke.  It sounds like your problem is the impeller (water pump). It is pretty straight but you must have a Seloc repair manual, if you have never done it before.  an important tip is to have the boat in gear when you remove the lower unit, so the shaft doestn move on you.  When you put it back on then the gear shat will go right back in.  I would also replace the thermostat to be safe, it is quick.
