Busman1973
- Apr 29, 2019
- 5
hi I want to know when I remove outdrive before I do it put gear in forward then I won’t have a problem when I put it back on. Also how far do I put in gear throttle thanks
Take your prop off and re install it after the drive is back on. Less chance of screwing the prop up if you drop it unexpectedly.
You can't damage it if it's not on
I do the opposite. I use a bungee on the prop blades to hold pressure on the gear, holding it in. Even if I just hand tighten the prop nut to put it on. How are you gonna damage a prop when the skeg sticks out below it?
Has to be in foward gear so the little gear selector arm thingy is pointed straight ahead. Make sure the prop doesn't freewheel both directions, if it locks one way you are good to go.
How do you make sure the prop doesn't free wheel?
Bondo...where exactly are you videos?
I looked around the site and couldnt find any..
I usually install the drives by myself on my boat. If you manage to drop it , chances are good when you're doing it alone, you could bend a blade. I just keep pressure on the shaft with my hand to stop the shift shaft from moving when I'm close to the end where it slides into the foot.
I actually have to install both of mine today..I'll be doing it with the props off
If you drop the drive, the last of your problems is going to be a bent prop!
Watch my videos to see how it's done properly, with zero chance of dropping it, and absolutely minimal risk of back injury.
I do have one question about doing it with the prop off. How do you turn the drive shaft to align to coupler splines if they are 'out' (which about 75% of the time they will be) without the prop on? :noidea:
Chris.........
