OK the carbs are installed, and I got it running. It needs to have the idle fast to keep running. I couldn’t find a deep enough tub, especially with everything shut down, so I put the muffs on it, and used a tub that comes about an inch short Of the top of the gear housing. So it’s got a combination of muffs And a shallow tub.
I have a good stream from the water pump but I’m wondering if water should also be coming out of those two black ports on either side of the outlet.
It did not get hot, but then again I didn’t run it very long.
