To get the corrosion protection layer off new points, use newspaper. It's abrasive enough to remove the film, but not the contact surface. NEVER use a file or sandpaper/emery on new points!
Chris....
If your gauge is accurate, your motor is getting tired, not worn out just tired. Agree your running rich
And this crap about 'set the gap, then set the dwell' just proves how little a few people understand, I mean properly understand, how a Kettering ignition system works. The gap sets the dwell. The dwell is a way to measure the gap using 'average voltage'...
Chris, I do take offense as I believe this was aimed at me...
Starting to sound like someone hasn't had there nap
Unless your working on an old chevy with a door in the distributor cap and allen head to adjust points, you have to set the points before measuring them
Its the wire it self, same as spark plug wires are made to have so many ohms per foot, the ignition wire is also made with resistance built in. It can be bypassed for testing, but should not be left that way.
If wire does go bad, it can be replaced with a regular wire and add a ballast resistor inline
I am restoring a 1972 Bertram 25 with twin Mercruiser 165 L6's. I recently ran all new fuel plumbing from the tank to the engines and removed the mechanical steering and replaced with hydraulic (mostly done). Replaced old trim pumps with alpha pumps and relocated them into a forward area and have removed or repaired a bunch of wiring in the engine compartment and helm area. Here are some pics of the engine and battery wells:
I finally got around to running her again today after all the work got completed and I can't get the Stbd engine to stay running. I was back there and in the helm area monkeying around for about 2 months on and off getting this work done and I am thinking I may have knocked something loose in the electrical system.
The engine turns over and fires when the ignition key is turned to start but seems to be running slightly too high of an rpm but when the key returns to the on position the engine dies right away.
During the survey this engine also had an issue "finding neutral" and I wonder if that and this may be related to the shift interrupt system?
I did check to make sure I have fuel at the carb so it is definitely an electrical related problem...
Any pointers?
Is it EST. Ignition ?
More likely not rite .
Nice and easy to work on. I envy you! I suggest new marine grade wiring and connector for that old of a boat. Trust me! In the meantime, you may want to swap coils if interrupter is OK??? I am not sure if your coils are internal or external resistant? Check code on both to be sure! I also had a distributor rotor become defective years ago. Get ohm meter out. Good luck!
