jredman941
- Jun 2, 2022
- 12
Troubleshooting 69 55hp johnson that won't shift into reverse or neutral, I'm not sure where the power is supposed to come from for this Electric shift, I get no power on blue or green wires.
Yeah, I know it has to be running, do you mean the throttle/shift control ?Split the control box.-----Perhaps the big $$$ switch is broken.----You are aware that motor has to turn to develop oil pressure for shifting.----Electric shift is wonderful and reliable.
Cool, I understand, what an I looking for in the shifter ?It needs to turn.----It will shift when turning the flywheel with a 1-5/16" socket.----Sorry----I have a bunch of these motor for parts.---But I have no idea what you know about these simple motors.
It's cool, I appreciate all the help, it's a johnson shifter, could abby of this problem be in the starter solenoid, it got real hot and the starter quit while the guy I was buying it from was trying to show me it it run.A broken switch.----The arm breaks off.----Or if you have the Evinrude control box it could be as simple as the red wire fallen off.----Sorry----I can not see , hear or feel your motor !
I replaced the starter but not the solenoid, it starts fine, I seen on the diagram that power was routed from the solenoid through the vacuum switch then on to the controlChecked the fuse.----might as well take the starter apart for inspection / testing.
I don't know the purpose of the switch, I have looked over the diagram alot.Do you know the purpose of that vacuum switch.-----Studied the wiring diagram?
So this could be my problem, any way to test the vacuum switch ?Say the motor was running in neutral at 2000 RPM and you turned the key to off.-----The gearcase would slam into FORWARD gear.------That switch applies 12 volts to neutral solenoid from alternator.----Would go into forward after motor slowed to a safe RPM.
I will, just trying to cover all possibilities so I don't keep bothering people, I really do appreciate your help, I have never dealt with Electric shift before.Sorry----I doubt that is the problem.-----Stop guessing on this simple system.----Check / test switch in the control box.
Maryville, tn. There is no power coming to the roller switch in the control boxYou have to be patient.----Perhaps find a manual.----Few shops will help you with these things.----And labor charges will shock you.----Your location?
I tested it for continuity and got no reading through both sides of the switchMaryville, tn. There is no power coming to the roller switch in the control box
