Okey, I have one question.
How did you split the CD module and how did you remove the insulation putty?
I think it is easy to repair the CD module if you manage to remove the putty.
The main components in the CD is the capacitors and the SRC transistors/thyristors and I think these two fail after avail.
The trigger voltage open the SRC and dump the stored capacitor voltage from the stator into the ignition coil.
CDI Electronics had a R&R system for the old Chrysler engines that was equiped with the MAG II system and they used some kind of solvevent to remove the putty.
