Mercruiser Setting Timing on 3.0L
kd4pbs
If the head cracked - due to improper tightening sequence even when there is a gasket that is compressing - then it would have surely failed while in service. A huge thick hunk of cast iron is much more resilient than you might think. The gasket will have already been compressed, so there will be no issue. But if you feel more comfortable following a sequence, then there's no reason not to do so.
As far as the lifter preload, I'm referring to the valve lash (zero lash plus the 1/2 turn or so preload). What you do when setting the lash is actually put a preload on the lifters which pushes the adjusting piston down into the lifter against spring pressure. It is imperative that this is done on the base circle of the camshaft where the lobes are not lifting the lifters. The best way to ensure this is that the cylinder be at or around top dead center on the compression/power stroke. Looking at where the rotor is pointing and working on only that cylinder is a great wat to ensure this.
I have a friend that built a very expensive hopped up 350 for his '68 Camaro back in the 80s. For some reason, he got it in his head that the cold valve lash (it was a solid flat-tappet cam) be set with the piston at TDC between the intake and exhaust strokes. Of course, this is 180º wrong and both intake and exhaust valves are open at this point, known as overlap. I was there when he first started it, and it sounded like a coffee can full of marbles in a paint shaker. I warned him immediately to adjust the valves the proper way, but he insisted on adjusting them by ear while the engine was running and the valve covers off. He never got it right due to constantly chasing the lash down as the cam was being wiped on every revolution. Poor guy. After he realized something was wrong and started tearing it down, it looked like someone sprinkled silver glitter in the oil. At least he realized the error of his ways after new bearings, rings, oil pump, cam, and lifters.
ESGWheel
Master Chief Petty Officer
KD,
Holy Cow Batman! Expensive lesson.
Dan,
More on what KD is talking about with respect to valve lash (aka valve adjustment). Your lifters that sit on top of the cam that the pushrod seats into are hydraulic (vs solid). Literally a little cylinder with a piston inside with a spring underneath and filled with oil. The preload pushes down that piston just a little bit and as the engine runs it compresses that piston and pushes oil out, up the pushrod, and oils the rocker. It’s really a marvel of engineering. Lots of vids out there and I encourage you to watch a few as part of developing your expertise. For the How To, idea is to mark the distributor cap plug wire sockets with which cylinder it corresponds to. See AD’s post no. 11. Do not have any wires in the cap. As you rotate the engine, keep pulling off the cap and eyeball to see if the rotor is pointing to one of the plug wire sockets. Look directly overhead when you pull off the cap, ie straight down along the same line that the dist. shaft would make if it was extended. That is the cylinder’s valves you can adjust. So initially takes a little bit of turn engine, pull cap and look, turn engine more, look again and until have it pointed almost dead on one of the cap plug wire sockets. Once done, rotate engine 180 degrees and will be at the next cylinder > pull cap to check and do that cylinder’s valves.
Looking forward to the pics once apart....
DanOnTheBoat
Wow amazing lesson lol. Oh man poor guy... Hope he learned his lesson...
I know exactly what your talking about now. That really helps a lot I'm going to save that. That answered everything.
This guy has a nice clear step by step process of everything:
Scott06
get the factory service manual for your engine/serial number. The Mercruiser manuals are excellent resources for all details like this.
I dont know off hand which manual you need, the only one I have for 4 cyl is #10 which covers 85-89 vintage engines.
the guy in the video is twisting them to determine when you are at zero lash- this can take getting a feel for when you start getting some drag on the pushrod. You are really looking for when any up and down slack is removed. If you tighten it until the push rod doesn't turn then go the additional half or full turn you will be too tight.
kd4pbs
Agreed. I used a Fel-Pro marine set on all the one's I've rebuilt.
You might want to check whether or not the 3 liter requires the head bolts to be sealed. I have never rebuilt one or done anything involving removing the head on one, so I don't know if the bolts extend into the water passages on this engine.
I use Loctite 1158514.
DanOnTheBoat
I heard Fel-Pro is mainly focused on automotive parts. I ordered myself a full MANHLE gasket kit. You guys think this one is good?
Scott06
Found a manual. I think it would be the same for my 2008 Merc 3.0TKS?
See page 67
Page 69 for pushrods and valves
that looks like a GM manual as it says industrial marine - so yeah it probably is right- the merc manual has the carb info timing etc for how merc dressed it out
per this link (may be worth what I paid for it..) you need manual #26 which is 98 and up 4 cyl gas alpha engines
kd4pbs
See page 67
Very good - it appears they don't go into the water jacket, so you won't need sealant on the threads.
Fel-Pro's marine sets are decent, but like Mike writes, you can't go wrong with Mahle stuff either as long as it's made for marine engines in mind. Both manufacturers make marine specific gaskets that use stainless steel in place of the regular steel they'd use in their automotive equivalents.
DanOnTheBoat
Hey guys, so just finished taking it all apart. Here are some pictures. Thankfully the culprit is the head gasket lol. Also I inserted 2 pictures of the head bolts. Not sure how visible or what sort of inspection they need. I cleaned them up with acetone and they don't seem to have any rust or anything. Just wondering if it's okay if I resue them.
Scott06
clean the head bolts and chase threads defintely ok to reuse.
It may be the picture but look at the block closely where the gasket was blown between 2 & 3 - make sure the deck surface is not damaged as it can get fire slotted and cut so the new gasket wont take.
Do you know if it overheated or if timing was to far advanced? Just want o ensure root cause of gasket blow is solved
