87 50HP VRO Evinrude - Could this be my problem?
saltchuckmatt
No, I have not simutaneously while starting but I will try. I'm usually alone when this happens so I have tried pumping the primer ball then going back to the console and turning the key. It's typically soft (but not collapsed) when I first grab it, and then it gets firm right away. I'll take a look at the spark plugs the next time I can work on it. I assume what I should be seeing is that they are wet, right?
Edit: also I plan to run a test this weekend, disconnect the fuel lines and splice them to a clear line running back to the fuel tank. Disconnect the starter +. Crank and check for air bubbles and decent flow, including the primer circuit when the key is depressed.
Wet or dry would give indications on where to look
I had originally notice that you weren't setting the high idle before starting so possibly a flooding condition or spark is your problem. Spark plugs can tell a story.
Take the starter apart for inspection.----Do an ohm test on armature.----Costs you nothing to do this simple work.
FishAtFive
Sure I can do that, I have two different manuals to follow for details. So basically you are thinking the starter is not spinning fast enough?
That is very possible ----and very easy to check out.----Don't rush out and buy a new one.----Test the one you have.----I install new brushes in these starters.----Got them from a starter alternator place at $6.50 each.
FishAtFive
How do they look? Seem fine to me. I will say that it is working just fine from an observational standpoint. It spins plenty fast, and when the motor catches it disengages.
Your meter is showing infinity.-----Which is the correct value.----Nothing wrong with the starter per your tests.----That now eliminates poor starter performance.----Something that was not known BEFORE the testing.
FishAtFive
Cool. Scratch that off the list. I also found this gem in the shop manual, not sure where half those things are:
FishAtFive
I think I can handle that. Those bolts probably are not seized. Will have to buy a new gasket though.
After doing some research, I should check to see if there is any air and fuel coming back out of the carbs before tearing it apart. I do faintly recall there is.
Is it normal to have any air or fuel coming out?
