Thank youYou know as long as that hose is full of water and your muffs are on tightly and you turn on the water before starting the engine it should be fine, I like to add the dawn because the impeller has been sitting dry all winter.
Thank youa little spray of water in the shaft hole is not an issue
you want to run the motor up to temperature at an idle with the hose on full blast
It may have been more than a little spray cause quite a bit got in the bellows before I turned the hose off…my litte contraption sprays upwards. is rust not a concern because it will dry out ?a little spray of water in the shaft hole is not an issue
Ayuh,..... No problem,...... Just keep the greasy parts, Greasy,.....It may have been more than a little spray cause quite a bit got in the bellows before I turned the hose off…my litte contraption sprays upwards. is rust not a concern because it will dry out ?
Thanks, figured I was probably overthinking it.Ayuh,..... No problem,...... Just keep the greasy parts, Greasy,.....
If yer that concerned, wipe things down with a rag,.....
Look at lower section of exhaust manifolds and engine block for cracks & rust stains and for water in the engine oil. Since I fill mine with PG AF I always verify freeze protection with a refractometer.Alright, so two more questions…I still have the outdrive off (didn’t get to trying to repair this Winter) and I attached the hose but forgot to put towels in the bellows before turning the water on. Some water got in the bellows and may have gone in the hole …is that a big deal or will it dry out if it did? I used a flashlight but couldn’t see if any got in there.
Second question, what am I looking for when running the engine to make sure nothing cracked over the winter. Just make sure temp doesn’t get too hot and look for leaks ?
Check for water in the engine oil just on the dipstick? How do you check for that?Look at lower section of exhaust manifolds and engine block for cracks & rust stains and for water in the engine oil. Since I fill mine with PG AF I always verify freeze protection with a refractometer.
Hey again, you were a lot of help to me winterizing last year Lou. I am unable to find the West Marine AF -100, but have you used this one? Is it a suitable replacement?if I choose to use AF…roughly how much would I need? Like 5 gallons? Also, I see some people talking about 50/50 but the label on the West Marine AF -100 says no need to dilute. Safe to just use straight from the jug?
Thanks Lou!That stuff is fine & is likely the same stuff as West Marine’s. If I can’t find the Sierra PG stuff that I mix with water I’d use it myself. So yep use that….
