1995 Crownline 202BR Restore
beta
Walking on a flat surface is severely underrated in my opinion
Words could not be truer. Can't wait to get the gas tank install and that compartment closed up as well.
I'm planning out some of the next steps and the depth finder transducer is on the list. It is a shoot through hull model and was previously attached in the rear, ~6" up from the center line. From my understanding, you want the transducer to be vertically level. However, the original was just epoxied to the hull without any spacer to level it. It's only about 15deg slope but still not vertical. Is it possible the unit compensates for this somehow? or would it just misread the depth (I assume it would show a slightly deeper depth than actual due to the angle).
Another question, since I'm going to gel coat the engine area, should I epoxy it to the hull then gel coat, or can I gel coat, then epoxy the transducer to the gel coat? Not sure if the gel coat will mess with the transducer signal if it's mounted on top of the gel coat. It goes through the hull already so feels like it should be ok but not sure.
Pmt133
Gelcoat is just good resin... ie what the rest of the boat is built with. I'd gelcoat then prep the area for the transducer and epoxy it over it. Imo it will look better that way as well
beta
Thanks. That's where my head was too.
I like the method described here so plan to go with it.
beta
Tabbed in the deck and PB'd all the joints between deck boards. Weather is suppose to be great this weekend so hoping to complete the foaming and get the deck glassed over.
Received my 3rd, and hopefully last, US Composite order today. When this is all done, I'll have to total up all the supplies. I know is it's A LOT of resin!
bakerjw
When I did my Stratos, I figured $2500 in materials.
When I passed $4K, I quit checking.
I used all epoxy though so that was much of it.
redneck joe
Project creep.....
Reminds me that I do have a spreadsheet going for mine, even tho I'm 'done' I do want to keep track of all in costs (minus fuel and beer/ice). Sold the spare motor so I get to deduct that now.
beta
Got the deck foamed in yesterday. My wife assisted which was a huge help. She was outside the boat mixing the foam and handing it to me inside the boat. Not having to jump in - out - in - out... was very nice.
I was getting nervous about running out of foam when I was about half way done but I ended up with ~10oz of unmixed foam remaining from an 80# kit. Big relief to finish and nice to not have a bunch left over.
I did receive the US composite order so I'm ready to rock. Today's plan is to gel coat in the gas tank area and get all the foam holes sealed back up. If all goes well, I'll glass the deck tomorrow.
Pmt133
I used a wire cup brush the diameter of the hole in the deck to knock the foam down and floated the wood pucks over top with peanut butter. PB in hole, press in puck, PB over top with plastic putty knife to trowel flat. Worked great. Then I hit them with the DA quick before glassing the deck.
Pmt133
When I did my Stratos rebuild, I remember looking into putting 2L bottles in the void to save on materials. I was less well off back then. The response was not pretty,
I feel that. While I wasn't exactly bursting at the seams with cash to do my resto, the project creep hurt after a while. That being said I got to the point where I had to decide if I wanted to cut corners now or deal with again down the line. To save on resin and glass I did not coat and glass the underside of my deck plywood. I figure with the foam being adhered to it completely and it being fully encased with no penetrations it shouldn't be an issue... but looking back I wish I just did it and the side boxes on both sides. What was another 5-10 gallons of resin and 12 yards of CSM really other than some weight... the original was done the same way and made it 40 years though. I'll be 70 at that point.
beta
Donuts are back in. I used a multi-tool with the grout removal head to take the foam off the top, it worked great. Then I used a die grinder with a cylindrical bit to grind out the hole. Also worked great.
Used PB to secure the donuts. It was simple but tedious work considering there were 64 of them!
Picked up some new fuel and vent lines yesterday so time to install the fuel tank and the decking over top of it. A completed the deck will feel glorious.
Lou C
Keep in mind your rebuilds are probably better than any boat you can buy brand new today. So yeah it's expensive but the time you take is what makes it better! Even my kind of half-assed resto on my old '88 F/W 19 years ago has held up well!
redneck joe
True, my new floor of MDO grade with OTF and three coats of appropriate paint will out last the original floor easy. Wanted to make sure whichever kid gets it when I go tits up can just use it. And all the new rivets....
