1995 Crownline 202BR Restore
beta
Walking on a flat surface is severely underrated in my opinion
Words could not be truer. Can't wait to get the gas tank install and that compartment closed up as well.
I'm planning out some of the next steps and the depth finder transducer is on the list. It is a shoot through hull model and was previously attached in the rear, ~6" up from the center line. From my understanding, you want the transducer to be vertically level. However, the original was just epoxied to the hull without any spacer to level it. It's only about 15deg slope but still not vertical. Is it possible the unit compensates for this somehow? or would it just misread the depth (I assume it would show a slightly deeper depth than actual due to the angle).
Another question, since I'm going to gel coat the engine area, should I epoxy it to the hull then gel coat, or can I gel coat, then epoxy the transducer to the gel coat? Not sure if the gel coat will mess with the transducer signal if it's mounted on top of the gel coat. It goes through the hull already so feels like it should be ok but not sure.
Pmt133
Gelcoat is just good resin... ie what the rest of the boat is built with. I'd gelcoat then prep the area for the transducer and epoxy it over it. Imo it will look better that way as well
beta
Thanks. That's where my head was too.
I like the method described here so plan to go with it.
beta
Tabbed in the deck and PB'd all the joints between deck boards. Weather is suppose to be great this weekend so hoping to complete the foaming and get the deck glassed over.
Received my 3rd, and hopefully last, US Composite order today. When this is all done, I'll have to total up all the supplies. I know is it's A LOT of resin!
bakerjw
When I did my Stratos, I figured $2500 in materials.
When I passed $4K, I quit checking.
I used all epoxy though so that was much of it.
redneck joe
Project creep.....
Reminds me that I do have a spreadsheet going for mine, even tho I'm 'done' I do want to keep track of all in costs (minus fuel and beer/ice). Sold the spare motor so I get to deduct that now.
