100:1 gas oil mix ( safe for most outboards)If you use the right oil!
TheOilDoc
Re: 100:1 gas oil mix ( safe for most outboards)If you use the right oil!
By LubeDude:<br /><br />Why on earth would I even mention a UOA in relation to 100:1 oils?
That's the question...<br /><br /><br />
By LubeDude:<br /><br />UOAs dont lie, they will out live Mobil1 every time.
You did use UOA and outboard oils in the same sentence. <br /><br />Mobil 1 is a NMMA TC-W3 certified outboard engine oil. Mobil 1 is an approved 2-stroke oil for UIM powerboat racing. UOA's have absolutely nothing to do with 2-stroke oils, although you tried to use them to show the Amsoil 100:1 is the best. Even the worst oil expert knows that UOA's have no place in 2-stroke oil discussions. <br /><br />BTW, if you're going to ridicule someone about their "intelligence", you might want to learn how to spell "common sense".
LubeDude
How can I get it through your head that we were not talking about 2 Cycle oils, we were "OFF TOPIC". You thick headed *****!!! You are really showing your true colors on this thread! :eek:
SpinnerBait_Nut
I don't know a dang thing about oils except I need them to run my engines.<br />What I do know is that ever time LD is in a discssion about oil, this oildoc fellow shows up and starts the same ol crap.<br /><br />Member TheOilDoc, why is that?<br /><br />BTW, I thought Mobil 1 was a car oil, see there, told ya.
SpinnerBait_Nut
Oh PS, I won't use any oil at 100 to 1, I do know that.<br />My ProMax is just to high to replace.
TheOilDoc
Originally posted by SBN:<br />What I do know is that ever time LD is in a discssion about oil, this oildoc fellow shows up and starts the same ol crap.<br /><br />Member TheOilDoc, why is that?
I am sorry you feel that way SBN. LubeDude originally addressed me in this thread on 8-15-05, a whole day prior to any post I made here. <br /><br />He followed up my response with argument and a comment about taking "pokes" at me. Since then he has called me names, used profanity, questioned my professional expertise, and attacked my intelligence and common sense. All while failing to explain his comments or provide any tangible or technical information.<br /><br />I have simply stated facts from Amsoil, offered members my experience testing oils at 100:1, and asked for explanations to statements made by LubeDude.
LubeDude
Originally posted by TheOilDoc:<br /> <br />He followed up my response with argument and a comment about taking "pokes" at me. Since then he has called me names, used profanity, questioned my professional expertise, and insulted my intelligence and common sense. All while failing to explain his comments or provide any tangible or technical information.<br /><br />
:p Wow, all that and you didnt even yell for the Mods one time. You may fit in eventually after all. :p <br /><br />If ya cant take the heat, stay out of the kitchen.
Elmer Fudge
Come on fellers, tone down the hostility, agreeing to disagree is not a discreditable attribute to one's character.
TheOilDoc
Obviously I "fit in" and "take the "heat" just fine. That's why LubeDude has an issue with me.<br /><br />I will remain under control and civil, only wishing that LubeDude could discuss oils with something more than personal attacks, insults, and opinions.
LubeDude
Originally posted by TheOilDoc:<br /> <br />I will remain under control and civil, only wishing that LubeDude could discuss oils with something more than personal attacks, insults, and opinions.
I would have no problem doing that if you would just kindly take my word that I didnt mean to make anyone think I was using UOAs in conjunction with 2 cycle oils. What part of we were "OFF TOPIC", dont you understand. We were talking about car oils at that time, not Mobil1 2 cycle oil or any othe 2 cycle oil. :mad: <br /><br />You have driven me to frustration trying to tell me Im saying or incinuating something that Im not. :confused:
SpinnerBait_Nut
I am really confused and had to take a nap, what I miss?
TOHATSU GURU
The usual..."I'm smarter than you", repeated over and over and over and over and over and over and over and over and over again.
cpj
Ensign
INTERNETOUTBOARDS, ROTFLMAO :D :D :D :D :D :D :D :D
JRJ
Sorry I missed out on the banter since I'm also an oil genius or not :D
Bwalker
It was pretty plain to me thta the UOA was in refferance to Amsoils four cycle oils being superior to Mobil 1...Their not.
orca
Question<br />Has an oil post ever gone to 4 pages before the mods step in.
LubeDude
Originally posted by Ben Walker:<br /> It was pretty plain to me thta the UOA was in refferance to Amsoils four cycle oils being superior to Mobil 1...Their not.
Yes they are, they are, they are too! :p <br /><br />They hold there additives longer, (they have more to start with).<br /><br />And the TBN stays higher because of it, thus Amsoil will go much longer between changes.<br /><br />Amsoil does thicken some though, which I find better than thinning out.
Wimperdink
So anyway is it ok to run amsoil mixed at 100:1 in my outboard? J/k I'm out of here before the next eruption. :D
Bwalker
"They hold there additives longer, (they have more to start with).<br /><br />And the TBN stays higher because of it, thus Amsoil will go much longer between changes."<br /> This is true, but only when comparing Mobil 1 oils that meet API specs to Amsoil oils that dont. Of course yuo no the effects of meeting API specs on additive treat levels. How would Amsoil's lame XL series(which are not even real synthetics), API cert oils compare? How would non API Mobil ER compare with Amsoil? How about Delvac 1 , T&SUV?<br />Amsoil is in no way superior whencomparing apples to apples and Mobil always uses bases stocks and additives which are more advanced and which they actually make. Do you honestly think Mobil is going to sell Amsoil their best base oils?
LubeDude
Originally posted by INTERNETOUTBOARDS:<br /> The usual..."I'm smarter than you", repeated over and over and over and over and over and over and over and over and over again.
I know this is just a joke, but I have never ever said anything about The OilDoc not knowing what he is talking about when it comes to oils, he is way past me on that one and I know it. He just rubs my fur the wrong way, thats all. :confused:
TOHATSU GURU
I should have left out the quotation marks, but let's face it. You two are on the opposite side of each other on almost everything....to the point of it being rather POINTLESS. You are funnier then he is...at least that helps.
