Re: 1957 Evinrude Fastwin 18HP Hopeful Resurrection
Hi 64. Yeah, that looks just like my situation. I noticed that in the second pic you might be able to get the cavitation plate to sit a bit more level by tilting/trimming the motor out one position (mine seems to run best on the second position out from the bottom:/ ), but you'll still be a little short. Raising it that last 2" may not make a huge difference one way or the other, but ideally the cavitation plate should be level, or slightly higher than the bottom of the boat to reduce drag. If you don't mind the work a jack plate is probably the best way to go. You can leave the original transom intact, which should save you from having to do any major surgery. There are all kins of designs out there. Most involve thick pieces of channel aluminum. Keep in mind, that adding a jack plate that hangs off of the back of the transom will essentially have the effect of lengthening the boat. So if the plate protrudes 1' of the back of your 14' boat, it will handle as if it were, in fact a 15'. Probably not noticeable on such a small boat and motor, but it can make a difference on larger craft. You'd like it to be adjustable, I suppose, so check out some designs for sailboat kicker motor mounts. They end to be relatively small, highly adjustable and easy to find and should work for motors up to about 18-20 hp, but not much more. Keep us posted.
