oldybutagoody
- Dec 30, 2011
- 207
Re: 1957 Evinrude Fastwin 18HP Hopeful Resurrection
Did you replace the fuel lines from the connector to the filter bowl, carb and manifold? Clean the sediment filter and bowl? Sure sounds like you're not getting fuel and you've ruled out the tank, tank hose and connector. Is the fuel fresh?
So after replacing the seals on the pressure tank line plug, I was able to try and test run my work.
It didn't run. Well only if I sprayed some mix in the carb. Took the carb off and inspected all the rebuild work. Blew air through it, checked the float, everything looked good. Stuck it back on, tried again and same result.
Tank has great pressure and runs a different motor, 90+ compression, good spark, breakers at .020, needles at 3/4 and 1 1/2 turns out.
I'm pretty sure I have a carb issue. What am I missing?![]()
