Re: 1959 Lake N' Sea Restoration
I did the dreaded flip today... No photos of the actual process, as I was KIND of busy. I did it alone, but with some pre-planning, it went smoothly.
I did it on the grass, to minimize potential damage. I lifted the bow with the gantry and a chain fall, and while that was lifted and supported, I went to the transom and lifted it & flipped it over... Sounds simple, but it was a workout! I ended up with some really minor scuffs in the new paint job from the chain, but they'll probably buff out without a problem.
Then I dropped it back on it's cradle- This is the same cradle that I used when it was upside down, I designed it to work BOTH ways. It was also designed to be used to hold the bed for my '66 ford truck project, too
You can really see the gloss that I was able to get with this paint-
Once I got it flipped, I cleaned up the inside, and gave it a coat of primer-
I need to decide what color the interior of the hull is going to be. Originally, it was a very dark grey Zolatone, but I think I'm either going to do it white or lighter grey.
-Andrew
