Finally got that wood back out last week. Now I am sanding and grinding away again at the transom this week. Any body need to remove wood out of a boat, I would highly recommend using a electric chainsaw. The worx 305 has done well digging out the old and new wood (mistakes that i made). It dug out that new wood in about 3 hours. So this time when i put the transom back in I will put the first layer (.70'') of wood onto the inside of the outer skin in pieces to make sure i get a good bond. I have not decided whether or not i will add another layer in pieces (.70'') or the entire board. I was also thinking to build it up in (.25" x 3) pieces after (.70") and just add mat between each .25 layer. I read it will be more stronger with more core layer. Its alot of board to handle alone and alot of thicken resin to cover in one large area.
