justinkaley2
- Jun 10, 2009
- 67
Re: 1976 Starcraft Chieftain 22ft. Cuddy Cabin Transom replace.
Yes. There's a return line from the steering to the trim pump. There's a hole in the steering for the "in" line and I'm sure I had one hooked to it. Two lines from the outdrive and only two holes in the pump. I am missing something. I hooked the lines from the outdrive to the bottom of the pump. The outdrive was down and when I tried to raise it ,it sounded at the end of it's move so I switched the lines I was able to raise the outdrive but it won't go back down. And oil comes out of the steering "in" line.
