Re: 1980s Coastworker 180 transom core replacement questions/advice sought
Just got a load more gelcoat (since I'm determined to do things the hard way!).
On closer inspection under the boat there's much more extensive scraping and gouging that's gone on, with one or two of the scrapes maybe an inch wide or so and running 1/2 to 3/4 the length of the hull! So I'm still giving thought to flipping the hull before I fit the engine so it's easier to sort all that damage. Not sure if I can easily do that with lack of space etc, so I might build a timber cradle above the boat where I can suspend it and pull out the trailer.
Would make sense as I can then do work on the trailer too since I've no idea how well the rollers work etc.
Not wanting to work on an overhead surface like this but I'm not sure I'd easily be able to get the boat on its side or upside down really.
Here's how it is as of last night:
