Re: 1980s Coastworker 180 transom core replacement questions/advice sought
Thanks Wood - appreciate the kind words.
It's been a lot of effort (and expense) getting it to this point but it's such a morale boost to get this far.
The outer skin should be a LOT less fraught to do, although of course will still be a little tense trying to ensure it gets bonded nicely flush with the rest of the transom.
I think for doing that, I will use some timber pieces across the full width of the transom when clamping, so that once the skin is pressed to the same level as the outer edges left on the hull, it then stops applying further pressure, resulting hopefully in a level transom.
Once that's done, I need to refit the transom cap (not sure how to ensure it's at perfect 90 degrees to keel?), then I can mount the engine and build the splashwell. I suppose I could make that first but difficult to measure everything properly like that without the engine being in situ I think.
