Re: 1996 mercruiser 5.7 with thunderbolt ignition ... Top End knock Please Help
I actually bout a new ignition system http://www.michiganmotorz.com/delco-...tor-p-119.html should be here on tuesday when i get home from work. I will try to enlarge the picture and repost it ( trying to avoid cracking the intake manifold off if at all possible). I did have to pull the vaccume advance off on the distributor in order to get the valve cover off and a brass plug on the inside of the exhaust manifold. Wonder if the vaccume got messed up when i pulled it off. :facepalm:
This thing is turning into a major headace lol just like everything else i own at the moment seems when one thing goes everything follows in suite.
Get proper plugs
Adjust both sides
Temp gauge should tell you if at operating temp, 15 min should be enough
Pictures are pretty small, looks like you at the very least have a roller ready block.
Easiest way for you to tell now by checking something and reporting back here is a bigger picture or just pull a push-rod and tell us how long it is. This really make no difference in you getting it running well.
Get the actual part number on the head the next time you have the cover off.
Distributor is potentially dangerous, looks like it is not a marine unit. It wont prevent you from setting the valves but i wouldn't take it out on the water.
