oldrem
- Nov 7, 2013
- 2,002
Need a little more water in the tub -- three or four inches above the pump (i.e., above the l.u. joint). Let it run at idle for a while and check the temp on the top of the head (130-140F, or so). Then shut it down and retorque the head bolts to spec.
A backfire (puff) back through the carb can mean an issue with the reed valves behind the carb -- think I would work on the air fuel mix a little first. You may be a little on the lean side, but I would do the counterintuitive thing first and lean it out just slightly. If you get a clear lean sneeze or stall, back it out 1/4 turn richer and try again (should be close for the mix).
This is a long shaft (5" extension), so I have the water well above the pump but can add more. I did a bore scope inspection of the reeds when I rebuilt the carb and they looked good. Will try the richer mixture and re torque tomorrow.
Thanks
