Re: 59 Rude foot problems
On the other side of the l/u is a slotted head screw, this is the actual drain hole for the lower unit. leave the phillips head screw alone. remove the slotted head screw. look at the pic that Shizzy posted in this thread, it will help you locate the drain screw. You have to fill it from the bottom screw because if you try to fill it from the top, the displaced air inside the lower unit will bubble the oil out all over you and the lower unit. Like I said before, the top screw hole will act as a vent to allow the air to escape as you put oil in through the bottom, slotted screw hole. when the oil begins to come out of the top hole, put the top screw, with a new O ring, in the top hole. this will form a seal and not allow much oil to run out the bottom hole as put the bottom screw, with a new O ring, in.
This is all done with the lower unit installed.
