'78 Ebko Lebaron - Therapy
  • Total voters
    13
  • Poll closed .
Trooper82
Re: '78 Ebko Lebaron - Therapy
Thanks TC...yes the rest did the old arms good....
Let's see if there is any progress showing in the pics?
Yesterday
Today
Decker83
Just another i-boater saying congrats on passing the test.. Glad to see you back at it.. Looking good as always..
Have a great week..:cool-new::clap2:
Trooper82
Thanks Decker!
Tha Admiral had be scrubbing the decks back in port this weekend (paiting the living room)
So boat work was minimal...
I did manage to get this much sanded and buffed..not liking the compounds I bought at that auto place...
jbcurt00
Buffing looks mighty fine from here. But I am not nearly as harsh a critic as you'll be, esp since you're up close & seeing it live....
Have a good pending week.
MikkiJayne
Just read the whole thread over about a week. Very nice work!
When I'm losing hope with my resto its threads like this which keep me inspired :)
Trooper82
Thanks and Welcome aboard...
hope the read wasn't too boring with all the non boat stuff...
GT1000000
Looking like a shiny new penny!
I completely understand about the compounds...the detail guy at the shop tried some off brand products a while back, and to say they were a disappointment compared to the 3M stuff is an understatement...:facepalm:
Kernallklink
Troop, how exactly did you manage to flip your hull? Mine is pretty similar to yours, and I'm trying to figure out how to do it without trashing the hull.
Btw, your project is coming along well, keep up the good work
Trooper82
You have seen the gantry's I built? (second set...much better than the first set) I used the bow eye for one place to lift...for the rear I bolted thick block of plywood I glued together, it bolts to the through holes for the out drive, then put an eye bolt through this down low...reason was to try and split the weight from bottom to top...taking into account the deck and stringers are low and heavy....hope that makes sense..
Here is a pick of the block...I haven't drilled the hole for the eye bolt yet, but it is barely clearing the key hole in the transom above the bottom through bolts that hold it in place
HoosierShooter
Trooper, what a read! I have spent the past 10-12 days reading the entire thread. Very impressive work and thanks for all of the notation and pictures, some of that will help me with mine. Carry on.
Trooper82
Why thank you...two folks on the same day saying they read ths whole thing...I just it is some help tp ithers, part of the reason I have tried to keep it documented....
Kernallklink
I looked at the gantries that you built, just not the plywood plate. Thanks for the info, I'll give her a go.
Trooper82
Little more sanding and polishing tonight...
Not much light on this corner of the garagemahall...
sphelps
The hull is really starting to look great ! How much more polishing do you have left before you can flip her back over ?
Trooper82
Thanks fellas...SP, if i had to guesstimate, i'd say I am a little over 3/4 done...but we can't forget i have quite a few places to add some gel to, so that will knock it down to maybe 5/8 done...weather turning cooler up here too...hoping to get some more gel down before it gets too cool..
