Lou C
- Nov 10, 2002
- 13,828
Re: 86 cobra 4.3 20drg.s to hot
I copied your pic and showed you where to spray some silicone spray so that you can slide down that lower hose on to the Y pipe. That hose has to slide down before the manifold will come off. Once you get that lower hose down the manifold will come off easily and then you can remove the upper hose and the aluminum exhaust pipe with it. Then check the outlets for rust clogging. As clean as that engine looks and fresh water use, I'd be a little surprised if they were clogged....
