Re: At the gelcoat stage - help needed!!!
Hey everybody, hope yous all had a good christmas,
Well another milestone almost reached, Weather & temp dependant I will be starting to paint the inside tomorrow.
Everything is prepped for painting, it took a large tin of bondo, a tin of glass filler, 6 square metres of glass, half a gallon of resin and another sanding marathon, but finally I'm ready for paint.
not much to look at just now but here is a couple of pics of the front end, this is where most of the work has been happening.
The part up front is the amplifier's base which i previously posted. Its all glassed and blended in now, This wont be seen at all though once I am finished cause the tv moulding will be going in front of this. I would liked to have the amps on show somewhere but this was the only realistic place to put them to help balance the weight and also so I didn't use up any much needed storage space, it's also prob the dryest part of the boat too.
The modification in the storage compartment you see is there for a couple of reasons -
1. The original design was terrible, to access the storage compartment I had to mess about and take the seat back rests off to let me lift the seat base which was always a pain in the ***. now the front seat base will have three different sections, a section at each side at the back rests which will be fixed to the modification i made and a centre section which will be hinged and on gas struts. Kinda hard to explain but it will all make sense as get on with the build.
2. a lot of the wiring will be getting routed behind this enclosure, so it will hide all the wiring, The large holes you see are for access hatches to get to the wiring if needed.
Hopefully have a few better pics tomorrow.
