Battery Trivia Question??????
brokemerc
Is there such a thing as a Group 27 Marine Starting Battery (Starting not Deep Cycle)??? So far NAPA and WestMarine both tell me one does not exist...
tashasdaddy
Re: Battery Trivia Question??????
yes there are, trojan, interstate. many more. there is now a combo starting/deepcycle batteries. of course they are more. go to a battery store, west marine going to carry the most expensive. walmart even has good ones.
brokemerc
Thanks,, I went to NAPA and they called their technical support for batteries and said there wasn't such a battery. Just called Westmarine and they also said there were no series 27 marine starting batteries.. I figured there must be someone who made one.. I've heard of these new deep cycle / marine starting combo type of battery. Anyone have any info on how well they crank/hold a charge?????? Thanks for the help..
Silvertip
Even my local farm store has them. They are also available in a group 31.
brokemerc
Just went to advance auto and they can't even order me one in a marine starting.. Everyone has them in deep cycle..
tashasdaddy
buy a starting battery, does not have to be marine, put it in the plastic box, and you are good to go. in batteries, marine starting is another way to charge more.
brokemerc
Yup I totally agree with you on that one. I have a regular marine starting group 24 now, I think i'll go to walmart or costco and pick up two regular auto group 27's, it's that bigger is better mentality.. THanks..
tashasdaddy
northen tool has a good deal on group 27 battery boxes.
brokemerc
Great,, I already have hold downs installed for the group 27's.. It's the ones that sit in a tray and has a top that bolts down on it. I don't leave the batteries in the boat and the boxes are a pain to work with.. Thanks..
dingbat
I have 2-group 27 installed so they do exist. I?m using AC Delcos but I know Boaters World carries Exides in the 27 size. The Exides are dual purpose and the Delcos are deep cycle.
I?ve had no problems with either one starting a 200 hp Evinrude
Boatist
A group 27 deep cycle should have no problem starting any normal marine engine. Maybe would have trouble with a very large deisel. I would go to Cosco or Walmart.
West Marine does have them but you get a better deal above.
Below is data from West Marine site
Group 27 dual purpose battery with 745 marine cranking amps. That would start a 500 cubic inch motor with no problem.
I could not find batteries here at Iboats.
West Marine infomation
SeaVolt Dual-Purpose 12 V Batteries
Manufacturer Style
SEAHAVEN - 009_272_002_005
If your motor runs frequently, and your electrical demands at anchor are light, dual-purpose batteries are an effective and economical choice. Our SeaVolt? Dual-Purpose batteries are specially designed to perform like deep cycle batteries. The result is batteries that deliver plenty of marine starting power while still able to handle moderate deep-cycle loads. SeaVolt? Dual-Purpose batteries can last through 200+ deep cycles (more than other brands advertising so-called "Deep-Cycle" or "Marine and RV" batteries) and still provide plenty of cranking power.
Built for West Marine by East Penn
Includes marine terminals (tapered posts and wing nuts)
SeaVolt? Dual-Purpose batteries cannot be shipped
Available at stores only
One-year free replacement; Three-year pro-rata warranty
Description WM Model# MFG Part #
Group 24,Ah 65,MCA 650, Res.Min. 120, L 10.75" x W 6.75" x H 9.88" Wt.39lb 1231000 DP24M Only $109.99 USD
Group 27, Ah 80,MCA 745, Res.Min. 150, L 12.5" x W 6.75" x H 9.88" Wt.49lb 1231059 DP27M Only $119.99 USD
dingbat
Group 27 dual purpose battery with 745 marine cranking amps. That would stare a 500 cubic inch motor with no problem.
You need to watch yourself battery sizes when dealing with the newer computerized motors. Mercury specifies a minimum of 1000 cranking amps or 850CCA for the Optimax. Some of the others may have similar needs.
Boatist
Dingbat is correct about the OptiMax. I can not imagine why but he is correct.
The V-6 Carb/EFI model up to 250 HP only need 630 Marine Cramking Amps but the OptiMax calls for 1000 Marine Cranking Amps.
V-6 Carb/EFI Models
135/200 & 225/250 630 Marine Cranking Amps (MCA) or 490 Cold Cranking Amps (CCA)
OptiMax Models
2.5L/3.0L 1000 Marine Cranking Amps (MCA) or 750 Cold Cranking AMPS (CCA)
brokemerc
Thanks for all the info. After calling around BoatersWorld is the only place I found that carried the series 27 and it's the dual purpose for $109 in the Exide. Thanks for all the help.
