I have a 9 year old boat, that recently started taking on water. After a bellow/ gimbal bearing service and replacement, it was still leaking. The mechanic who did the bellow service told me that he droped it in the water afterwards...and no leak. Then I took it out the next day...still leaking. Took it back to him. He said that he put it in the water again, and this time he could tell that the water was coming in from the transom, where the outdrive connects to the boat. He told me that the transom seal might be bad, or that the bolts on the transom plates might not be tight, or that the outdrive might have shifted if it struck something, he didn't know. He said he would need to pull the engine, just to see what the problem was...$900 for the engine pull only...before even starting on repairs.
Called another mechanic. He said there is no use to pull the motor. He said if water has got past the transom seal, then the wood has gotten wet, and is therefore ruined. He said that without completely rebuilding the transom, it could never be right. Instead he recommended putting 5200 sealant around the outside of the outdrive...@ $200. He said its a common problem and thats what they usually do instead of trying to fix it. He said it will last for years.
Which one of them is being straight?
