anthonysjo
- Mar 10, 2009
- 51
I have a clogged speedo tube...I have read that I need to blow it out towards the gear case with air and that I should clean the hole with a 1/16 drill bit.
It has not worked thus far and it has been clogged since I have owned the boat (8 years) but I want to get it working.
What can I do?
The drill bit barely goes in, less than 1/32 and I see some metal. I then took a small pick tool and dug all the dirt out and it looks like the metal is laying horizontal but I can stick the pick in above and below a little. Should that metal be there?
I have tried sticking a #12 wire down the tube without much luck.
Should I spray anything down the tube or can I tear the lower unit off and get better access?
Please let me know any bright ideas as I would like to get this working.
Thanks!!!
What can I do?
Thanks!!!
