I agree to a certain extent what you guys are saying. It does amaze me that these boats do as well as they do for as long as they do given the shoddy construction. The stringers in my Chap weren't bedded well at all and were completely rotted through. The only way you knew they were rotting was one soft spot in the floor.
If you rebuild the boat exactly the way it was you pretty much guarantee it to last as long as it did originally. If you build it the way it was using proper methods it should last pretty much forever. I don't feel that making a few improvements such as adding a bulkhead is going to take away from the original engineering. The original design engineering was to make it safe, as solid as possible as cheap as possible which means less material and more importantly less labor to build.
If you bed and tab the stringers, bulkheads, and floor in properly, and use foam, there's not going to be much flex if any. I am adding an additional bulkhead to create additional support and eliminate a weak spot in the deck. A weak spot engineers wouldn't know existed unless they have wet kids jumping around to test their designs.
