Re: I need every bit of top speed out of my V/P 5.7L AQ200d 280 outdrive.
alright, I did the compression test.
This is how I did it:
Pulled all plugs, put the throttle at wide open, pulled the coil to distributor wire.
Cranked the engine 4 to 5 times, recorded the highest reading. The engine wasn't warmed up prior to the test.
Results are:
CYL 1: 72 psi
CYL 2: 66 psi
CYL 3: 72 psi
CYL 4: 65 psi
CYL 5: 63 psi
CYL 6: 45 psi
CYL 7: 63 psi
CYL 8: 62 psi
Pretty damn sure these are not the numbers I wanted to see. I thought a 350 was supposed to be in the mid 100's for psi.
thoughts?
Results are:
CYL 1: 72 psi
CYL 2: 66 psi
CYL 3: 72 psi
CYL 4: 65 psi
CYL 5: 63 psi
CYL 6: 45 psi
CYL 7: 63 psi
CYL 8: 62 psi
thoughts?
