Re: Identify this Volvo motor!
Does standard automotive antifreeze work, or is there a marine flavor that should be used?
The sea water strainer is on the impeller side I assume?
If I understand this correctly, There are two cooling systems going on here. The first is closed loop which circulates thru the engine only. The second comes from the intake in the outdrive, in through the heat exchanger, (Not in contact with the actual closed loop coolant, just in the same exchanger), then exits via the exhaust. Is this correct, or am I just more confused?!?!
Maclin, any idea of an owners manual for this motor out on the internet somewhere, preferably in PDF format?!?!
