The Purge Ports can't be used by a manometer? There's vacuum there. Are the air screws adjusted by ear, or is there a Factory set way, to balance the 3, after teardown and reassemble? Just trying to do it right. Thanks for the help. I'm waiting on carb kits, in the meantime I'm rebuilding the water pump. Also using too much Sea foam in the fuel ,eats up Fuel Pump diaphragms. Done that before I swapped out the coils and master ingnition module. It's easy to blame top end preformance on the fuel system when the Fire isn't there. I will post how everything turns out after the redo. Thanks again
