Re: Limited to 9.9hp
I got the three blade prop last Friday, this weekends warm weather was perfect to try it out, I also took along several of the fins to try.
First off, I ran it with the two blade prop with a Stingray Jr. fin, it sunk low into the water on take off and would begin to climb back up but then drop back down, and it did that over and over. I switched to the 9x7" three blade prop, this one an OEM Mercury prop that I found at a dealer out west. The 9x7 three blade prop without the hydrofoil eliminates almost all the sinking on take off, but it also didn't propel the boat well at all, the motor can over rev with that prop, I limited it to to 6000 RPM manually. I then added the hydrofoil again, and this time it would pop up on top of the water almost instantly, within about 15' or so, but I had very little speed, maybe 10mph or so, plus, everytime I hit a disturbance in the water or crossed another boat's wake, the prop would lose grip and slip.
The OEM prop has narrower blades and no hub flare compared to the MI Wheel 9x7 I already had which has wider blades and a flare on the hub where the exhaust exits.
I switched to the MI Wheel 9x7 prop and it drops the boat in a hole much like the 2 blade did, I then added a hydrofoil and that helps but the boat would pop up on plane pretty fast but then it sort of settles back in and only cruises along at maybe 9 mph, even slower than the Mercury three blade. The MI Wheel prop doesn't seem to lose grip as easy as the Mercury prop.
The 2 blade never loses grip with no hydrofoil but does when turning with a hydrofoil in place. I tried three brands of hydrofoils, Stingray, Doelfin, and Attwood, the Attwood affected the speed the least, the Doelfin and Stingray were about equal in lifting the stern, but the Stingray seemed to create less spray and turbulence behind the boat. The Attwood model, which is angled upward on both sides, got nearly completely out of the water but would settle back down till it was riding on top. I don't think any of the tests I did were a good comparison of the hydrofoils, but the Stingray seemed the best overall and it by far fit the best on the smaller motor.
The Doelfin seemed to lift faster and higher but its shape is more like an air plane wing then the others, giving it some natural lift plus the turned down rear edge. Being thicker, it probably has the most drag when in the water.
Nothing so far has ran as good on this boat as the 6hp did. I went back to the lake with the 9x7 Mercury prop on the motor and a different boat, I took a 12' Duranautic and tried that with the new prop and it was better, it didn't take on water, but it didn't go very fast and it wouldn't plane the boat. I took along a borrowed 9.5hp and it flew across the lake, even with me at the stern with a 130lb passenger up front. With just the 130lb driver, the 9.8 Mercury flew with the original 2 blade prop and the Stingray hydrofoil on the back. It would jump right up and take off. I tried the 9.8 with no other weight but myself in the middle seat and it half sort of got on plane but struggled on the edge of taking off like it should.
Today, I did one more test, I borrowed an older Polar brand modified V hull 16' boat from a buddy, its a bare hull, extra wide, which weighs in at 240lbs. Me and a 200 lb buddy took that out with the 9.8hp with the two blade prop and Stingray hydrofoil and it popped right up on plane and cruised along at about 14 mpg on his phone's GPS.
If we both sat side by side on the split bench in the middle, the boat would gain two mph.
He runs that boat normally with a 35hp Evinrude in the river. I think all I accomplished there though is convincing him to add a hydrofoil to his 35hp. I was temped to hang his 35hp on the Starcraft and try that combo but figured the weight would nearly sink the boat if it did the sinking trick on take off.
I also tried a 2004 Mercury four stroke 9.9hp motor which I borrowed, I'm not sure of which prop it had but on take off, it too sinks low in the water but not as low as the 9.8hp two stroke, but the difference is that the 9.9 four stroke pushed the boat at a pretty good clip even though it didn't get on plane. The resulting wake behind the boat was pretty bad. I didn't try that with a hydrofoil since it wasn't mine to drill holes in.
I didn't try the aluminum hydrofoil since it was so big and I'd have to cut and carve it up to make it fit the small motor properly. I figured it wasn't worth the risk of destroying it for something that may or may not work in the end.
I did see one boat running on the lake on Saturday that was running a 9.9hp Suzuki two stroke, the boat was about a 14' Mirrocraft with three grown men on board, the boat was on plane and traveling at a fairly good speed. I made a point of checking out the set up and that boat had two 13" long lengths of aluminum angle iron welded on both sides at the water line, flush with the bottom of the hull. Each angle was bent down just a bit. The guy said that without them the boat won't plane. Sort of a fixed trim tab. The angle was about 1 1/2" from the back of the boat. Of course, I'm not sure I'd be so willing to weld or rivet such a thing on the back of my super clean hull, but it did seem to work and it wasn't putting any stress on the motor's AV plate or clamps.
