JimS123
- Jul 27, 2007
- 8,250
Re: Limited to 9.9hp
The angle of the pic might be deceiving, but it sure looks like a long shaft motor on a short shaft transom. The "cavitation" plate is the one above the prop - that's where the measurements are made.
The mounting hole is at the bottom of the transom bracket. If that's a photo deception as well, tilt the motor up and use a u-bolt through the center of the transom bracket. ALL motors can be bolted on - some just require a little ingenuity.
