Re: Man vs. Boat (season 1).
Hey PM,
Looking at your vid I came up with another possible way to curve your plywood. Make some Kerf cuts vertically, start with 4- 6, 1/8-1/4" deep, and test to see if that gives you enough of a bend...add more or deeper ones as needed. I believe that with a good resin wet out, some PB in the kerfs, maybe a layer of CSM, and a good layer of PB before you attach it to the hull, you should be OK...The biggest difference is you would probably have to lay in the transom as two separate layers, instead of just one...Or Pre-curve both pieces of plywood, adhere them together, and then do it as one piece...
Plus, cutting away the sections you mentioned should definitely give you the clearance for the installation.
And you don't have to basket weave it...LOL
Regards,
GT1M
