- Apr 17, 2002
- 71,409
As far as additives I think the gear lube is different because of water intrusion. Water displaces oil I think it has an additive to help the oil and water mix.
Ayuh,.... In all my years, the only difference I've found is,....
They add a pretty colored dye to the marine gear oil, where as automotive gear oil is natural amber colored,.....
Btw,... I run run only Syn-oil gear lube, either Mobil 1, 75W-90, or Pensoil 75W-90,...
'n both will still lube things, with nearly 1/2 the case fulla water,....
Years ago, I worked for a small marina, when changin' gear oil in the many outboards, 'n I/Os, the replacement oil came outa a 5 gallon pail of Napa 90W ep hypoid gear oil,....
