After a lot of consideration I dont think im gonna remove the camshaft, head or timing gears. The camshaft lobes do show some wear but i dont think its enough to cause any bad lifters. There is no knocking or ticking. I hope you guys can tell me what you think about the camshaft lobes...
Regarding the timing gears, i looked over the camshaft fiber timing gear and it looks uniform, no missing or broke or ground down teeth.
Regarding the head, it gets on plane, spark plugs are dry, doesn't overheat, doesnt leak and there is no water in the oil. I was thinking about taking the head to the shop but for now i don't have any problems from it. I have no reservation about having my head looked at and or rebuilt, i think i just wanna wait till there is a reason suspicion to do it. Plus, if and when the head presents a problem i wont have to take the whole motor out again to resolve that kind of issue. My main and biggest problem i believe is from the intake. After i get my lower end together i'll move on to the intake.
Im open to any opinions or advice on my thought process...
This cam below with the orange background is NOT my cam. Its just for reference. I thought it would be helpful for any other noobs out there like my self who are learning as they go. Im sorry chevymaher for the confusion.
in retrospect, i probably should have spun the cam and inspected the entire surface of the lobe....
will do that next time im at the engine...
the good news is if the cam lobes are good the lifters should be goods as well...
